1996 Ford Explorer
BENANDREW
  • 1996 FORD EXPLORER
Electrical problem
1996 Ford Explorer V8 All Wheel Drive Automatic
engine cranks over but will not start.
Do you
have the same problem?
Tuesday, December 23rd, 2008 AT 1:28 PM
BLACKOP555
  • EXPERT
First you need three things for the vehicle to start.
Fuel, ignition, compression.
Since I doubt its compression if the vehicle was running just fine untill you tryed to start it one day we can rule that out for now.
Next step is to check for fuel pressure and the presence of ignition at all cylinders.
You can do this by dumping some gas down the throttle body and starting it.
Thursday, December 25th, 2008 AT 4:17 PM
Recommended Guides
