1995 Ford Explorer I have no heat
MATTY4269
  • 1995 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 160,000 MILES
I have no heat in my truck, I changed the thermostat yesterday thinking that was the problem, but it didn't work. One hose going into the heater core is hot and the other is cold. I don't know what else to do. Any suggestions. Thanks matt
Do you
have the same problem?
Monday, December 7th, 2009 AT 9:32 AM
  • EXPERT
If you have one hot and one cool heater core hose, it sounds like the heater core is plugged. The best thing to do is to remove the hoses and both flush and back flush the core to see if the water passes through it. At any parts store, you can get the flush. Just follow the directions that come with the cleaner.
Let me know if it helps.
Wednesday, December 9th, 2009 AT 9:29 PM
Recommended Guides
