My check engine light just recently came on. I ran the codes and it turns out to be my O2 sensor (bank 1, sensor 1). I have the 4.0 SOHC. Is this sensor located on the passenger side of the vehicle in front of the converter? And if so, can this be changed without having the car on a lift? Thank you.
SPONSORED LINKS
have the same problem?
Friday, February 20th, 2009 AT 8:43 AM
