1994 Ford Explorer Shifting
FRANK MILLER
  • 1994 FORD EXPLORER
  • 6 CYL
  • MANUAL
  • 287,000 MILES
I had my clutch go out. I replaced the clutch, slave cylinder, and fly wheel. It drove fine for about two month's. Then I noticed sometimes when I would change gears it would go into gear hard. Then one day it went into reverse and got stuck. Had to yank it out of gear. Then after that was told I needed a clutch master cylinder. Replaced that. Now it goes into gear but I have to push the clutch all the way to the floor just to change gears and it's hard to put it in gear.
What may be the problem now?
Do you
have the same problem?
Thursday, April 22nd, 2010 AT 9:40 PM
  • EXPERT
With the engine off, does it shift smoothly?
Friday, April 23rd, 2010 AT 7:47 AM
Recommended Guides
