1994 Ford Explorer Rear window regulator
WWTRIGGS
  • 1994 FORD EXPLORER
  • 6 CYL
  • 160,000 MILES
Passenger side rear power window will roll down part way then slips and must be helped up. Is there an adjustment or repair that would stop the slippage?
Do you
have the same problem?
Saturday, August 29th, 2009 AT 6:57 PM
JGAROFALO
Most lilely the drive gear is worn out. This part is not serviced seperately. You need to replace the motor assembly.
Tuesday, September 1st, 2009 AT 6:41 PM
Recommended Guides
