Where is the fuel filter?
MELONY HICKS
  • 1995 FORD EXPLORER
  • 2.5L
  • 6 CYL
  • 4WD
  • 20,000 MILES
Where is the fuel filter located on this vechile.
Sunday, January 27th, 2019 AT 2:58 PM
SCGRANTURISMO
  • 4,897 POSTS
Hi Melonie Hicks, my name is Alex and I will be helping you. Here is the information you requested. It's near the tank under the vehicle along fame rail. This video will help you remove the filter with instructions below to show you how to replace the fuel filter in your car.
https://youtu.be/Boi0DPXVHbM
and
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Hope this helps.
Monday, January 28th, 2019 AT 12:34 AM
MISSMAGGIEMAY
  • 6 CYL
  • 4WD
Where is the fuel filter on a ford exploer 1995 xlt?
Wednesday, October 7th, 2020 AT 1:33 PM (Merged)
WRENCHTECH
  • 20,757 POSTS
It's mounted inside the frame rail on the left side, just behind the driver.
TEEOFF2
  • 6 CYL
  • 4WD
  • 94,000 MILES
Is there a tool to change fuel filter it well not come off when I pull the clips off.
BLUELIGHTNIN6
  • 16,542 POSTS
Clean all dirt and/or grease from the fuel filter fittings. "Quick Connect'' fittings are used on models equipped with a pressurized fuel system. These fittings must be disconnected using the proper procedure or the fittings may be damaged. The fuel filter uses a "hairpin'' clip retainer. Spread the two hairpin clip legs about 1 / 8 in. (3mm) each to disengage it from the fitting, then pull the clip outward. Use finger pressure only; do not use any tools. Push the quick connect fittings onto the filter ends. Ford recommends that the retaining clips be replaced whenever removed. The fuel tubes used on these fuel systems are manufactured in 5 / 16 in. And 3 / 8 in. Diameters. Each fuel tube takes a different size hairpin clip, so keep this in mind when purchasing new clips. A click will be heard when the hairpin clip snaps into its proper position. Pull on the lines with moderate pressure to ensure proper connection. Start the engine and check for fuel leaks. If the inertia switch (reset switch) was disconnected to relieve the fuel system pressure, cycle the ignition switch from the OFF to ON position several times to re-charge the fuel system before attempting to start the engine.
Thanks for using 2CarPros. Com!
JOHN GROBELNY
  • 6 CYL
  • 4WD
  • 185,000 MILES
To separate the gas filter from the gas line is there a special tool or do you force it off and on
JGAROFALO
  • 489 POSTS
There is a special tool required. The tool is readily available at most parts stores and is not very expensive.
AUSTIN543233
  • 6 POSTS
I used a sharpie cap and cut it to size and it worked perfect
FUEL FILTER LOCATION
https://www.2carpros.com/forum/automotive_pictures/12900_fuelfilter_2.gif
REMOVAL
CAUTION: If the fuel filter is being serviced with the rear of the truck higher than the front, or if the tank is pressurized, fuel leakage or siphoning from the tank fuel lines could occur. To prevent this condition, maintain the vehicle front end at or above the level of the rear of vehicle. Also, relieve tank pressure by loosening the fuel fill cap. Cap should be retightened after pressure is relieved. If vehicle is warm, change the fuel filter before the pressure rebuilds.
1.Shut engine Off. De-pressurize fuel system. Use caution to prevent combustion from fuel spillage.
2.Raise vehicle on hoist.
3.Remove push connect fittings at both ends of fuel filter. Install new retainer clips in each push connect fitting.
4.Remove filter from bracket by loosening filter retaining clamp enough to allow filter to pass through.
INSTALLATION
1.Install filter in bracket, ensuring proper direction of flow as noted by arrow. Tighten clamp to 1.7-2.8 Nm (15-25 lb in) . NOTE: The "flow" arrow direction should be positioned as installed in bracket to ensure proper flow of fuel through the replacement filter.
2.Install push connect fittings at both ends of filter.
3.Lower vehicle.
4.Start engine and check for leaks.
Wednesday, October 7th, 2020 AT 1:34 PM (Merged)
MADPOOH42
  • 1994 FORD EXPLORER
1994 Ford Explorer 6 cyl Four Wheel Drive Automatic
were do I find fuel filter on truck
BLUELIGHTNIN6
  • 16,542 POSTS
The fuel filter is mounted to the drivers side frame rail by a bracket, pictured below..
https://www.2carpros.com/forum/automotive_pictures/261618_1_16.jpg
Thanks for using 2CarPros.com!
BLONDEMOMENT4US
  • 1992 FORD EXPLORER
Engine Mechanical problem
1992 Ford Explorer 6 cyl Four Wheel Drive Automatic
My name is Tiffany. I am attempting to replace the fuel filter on my 1992 ford explore and am having some complications trying to take it off. I have pressed the pressure release valve and it just doesn't want to come off. Are there any tricks that I should know about. I would greatly appreciate the help.
Wednesday, October 7th, 2020 AT 1:35 PM (Merged)
OBXAUTOMEDIC
  • 3,711 POSTS
Hi Tiffany,
Did you remove the to sliding clips on either end?
Also if it has been a while since last filter change it may take some elbow grease to get it off.
SHANNON_TYREL_1985
Other Category problem
1992 Ford Explorer 6 cyl Four Wheel Drive Automatic 169xxx miles
how do you take the fuel filter off? I'm having trouble with geting the fuel vlines loose
JFALLS6880
  • 5 POSTS
You need to buy a air conditioning and feul lline disconnect tool set. It cost like $10 at the parts store. It comes with 6 plastic rings (different sizes for different size fuellines) . You place one of the rings
https://www.2carpros.com/forum/automotive_pictures/130938_S3500081_1.jpg
around the fuel line and then push it towards the fuel filter and then pull the fuel line out. Make sure the fuel line is depressuirzed your you'll get waht ever fuel is in the line right in the face. I know from experience.
STONER.BROOKS
  • 1991 FORD EXPLORER
1991 Ford Explorer
where is the fuel filter located at
Wednesday, October 7th, 2020 AT 1:36 PM (Merged)
DLOBI
  • 125 POSTS
Your fuel filter should be frame mounted (drivers side I think). You will find it along the fuel line from the tank to the engine under the seating area.
JWALTH02
  • 180 POSTS
The fuel filter you're gonna need to go to autozone and purchase the removal tool. Either the little plastic ones that are like $7 that have a tendency to break or the metal one that's like a screwdriver that's much nicer that I don't know the price of.
Then just slip that around the fuel line and push it into the fitting and pull it apart.
ROBERT CARR
  • 1993 FORD EXPLORER
  • 200,000 MILES
I need to change my fuel filter where is the location?
FIXITMR
  • 9,990 POSTS
The fuel filter is under drivers seat on frame rail here is a video to help you remove the lines and a diagrams below to show you the location.
