1994 Ford Explorer Car Won't Start
MBRYANT428
  • 1994 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 190,000 MILES
Recently the car would not start in cold weather. When it did start, it ran fine. Then we replaced the battery and the car cranked twice and then died and would not start. We had it towed to the shop today and they said it was the fuel pump and fuel filter. They replaced it and we picked it up and drove it probably less then 15 miles and when we went to crank it back up, it sputtered and died. Now it wont crank at all. Does anyone have an educated guess as to what this might be?
Do you
have the same problem?
Friday, February 12th, 2010 AT 4:20 PM
  • EXPERT
Rather than a theory, I need you to check something. If the car won't start, it is most likely missing spark of fuel. I need you to check for both so I can give you a better idea of what you are dealing with.
Here are the how to's for you.
http://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
http://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
Friday, February 12th, 2010 AT 4:47 PM
