1993 Ford Explorer No heat or A/C
MOOTSIE
  • 1993 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 130,000 MILES
It started as a grinding noise, then it began thumping (this was loadest when control was on high), the next thing was a very strong burning rubber smell. After that we had nothing! No heat and no A/C. I took about a week for it to completely stop. It makes no noise. The fuses are fine. All gauges are fine. Truck runs good. I have major breathing problems and need the ac. I cant afford a tech. And I cant afford to play the process of elimanation. Please help.
Do you
have the same problem?
Monday, July 5th, 2010 AT 4:14 AM
Inspect and test the blower motor
Monday, July 5th, 2010 AT 12:46 PM
Recommended Guides
