1992 Ford Explorer no brake pedal
ANIMAL39
  • 1992 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 150,000 MILES
I replaced the master clynder bench bleed it and then bleed the wheels had a good pedal then when you start it to drive it rear antilock stays on with a weak pedal
Do you
have the same problem?
Saturday, September 18th, 2010 AT 6:08 PM
BLUELIGHTNIN6
  • EXPERT
Test out the vacuum power booster
Tuesday, September 28th, 2010 AT 8:20 PM
Recommended Guides
