1992 Ford Explorer Brake Lights
KINIC
  • 1992 FORD EXPLORER
  • 6 CYL
  • 172,000 MILES
I just replaced the wiring harness for my brake lights because one of my brake lights went out. AFter doing the repair I now have tail lights but when I hit the brakes the drivers side goes out. I checked the harness and I have no frayed wires that I can see, none of my fuses are blown. I have no idea what to check next, please help.
Do you
have the same problem?
Saturday, February 13th, 2010 AT 7:57 PM
  • EXPERT
With the new wiring harness, did you get new light sockets? Also, have you tried running a seperate ground for the side that doesn't work?
Sunday, February 14th, 2010 AT 2:20 PM
KINIC
I did not get new scockets with the harnesses. My rear lights work it is just when I hit the brakes the drivers side goes out. Also how do I run a new ground on the drivers side if all wires are enclosed inside the harness?
Sunday, February 14th, 2010 AT 3:44 PM
Recommended Guides
