1992 Ford Explorer
CARLOSCCHAVEZ
  • 1992 FORD EXPLORER
  • 6 CYL
  • 100,000 MILES
MY TRUCK IS PASSING GAS TO THE VACUUM HOSE AND WOUND START
Do you
have the same problem?
Thursday, September 3rd, 2009 AT 12:53 PM
JGAROFALO
Take the vacuum line off the fuel pressure regulator, and see if fuel is coming from the vacuum port. If it is, then you need to replace the fuel pressure regulator.
Wednesday, September 9th, 2009 AT 2:04 PM
Recommended Guides
