1991 Ford Explorer car dying
ENGTRAINS
  • 1991 FORD EXPLORER
  • V8
  • 4WD
  • 127,000 MILES
You will be driving along and all of sudden it will die. Let it set for awhile and it will start and run again for awhile. I have had the fuel pump replace and the fuel relay fuse replace and the wring from the relay to the fuel pump. Right now it will run for a few days then all of sudden quit. Could it be the fuel shut off switch if involved in a accident relay? I have done everything I can.
Do you
have the same problem?
Monday, September 8th, 2008 AT 9:29 AM
BMRFIXIT
  • EXPERT
Check for spark check crank sensor
Monday, September 8th, 2008 AT 9:54 AM
Recommended Guides
