2003 Ford Expedition Unusual Symptom
BILLG12
  • 2003 FORD EXPEDITION
  • V8
  • 4WD
  • 134,000 MILES
From a cold start, engine temperature reaches normal then spikes high with hi temp light on dash after ~10 minutes; heaters (front and rear) blow cold; after 15-30 seconds, engine temperature returns to normal and heaters function normally; carbon monoxide detected in engine coolant; thermostat replaced - no change in symptoms
Do you
have the same problem?
Tuesday, November 11th, 2008 AT 11:39 PM
BLUELIGHTNIN6
  • EXPERT
Could be a faulty thermostat.
Wednesday, November 12th, 2008 AT 12:02 AM
Recommended Guides
