Check engine light?
JUSTIN1457
  • 2003 FORD EXPEDITION
  • V8
  • 140,369 MILES
My engine light will not go off on my 2003 ford expedition it failed the emission test the paper work said the bank 1 and bank 2 mix to rich so I replaced both 02 sensors and the mass air flow sensor too but light is still on do I need to have a tune up done or should I replace all the sparks plugs to?
Do you
have the same problem?
Monday, June 22nd, 2009 AT 3:27 PM
LEGITIMATE007
  • 5,121 POSTS
Did you erase the codes after replacing those items? if not go over this guide to get the codes and report back.
joe
Tuesday, June 23rd, 2009 AT 12:10 AM
JUSTIN1457
Yes I have to codes erase
Tuesday, June 23rd, 2009 AT 11:13 AM
LEGITIMATE007
  • 5,121 POSTS
At this point then I would check fuel pressure, and the engine coolant temperature sensor, I 'll send u alink that will show you how
Tuesday, June 23rd, 2009 AT 1:03 PM
LEGITIMATE007
  • 5,121 POSTS
This link will show you how to check fuel pressure.
Tuesday, June 23rd, 2009 AT 1:04 PM
LEGITIMATE007
  • 5,121 POSTS
The engine coolant temperature sensor may be telling the computer that its cooler than it supposed to be, thus the computer will start dumping fuel into the combustion chamber throught the injectors, I dont think that you have several bad injectors although it is possible
Tuesday, June 23rd, 2009 AT 1:06 PM
JUSTIN1457
I are sorry but when I looked at the emission report it said bank1 ans bank2 too lean not to rich what does this mean? Thanks for all the help
Wednesday, June 24th, 2009 AT 9:09 AM
LEGITIMATE007
  • 5,121 POSTS
You still will need to check fuel pressure, low pressure could indicate a bad regulator of clogged fuel filter
Wednesday, June 24th, 2009 AT 4:19 PM
MSEMMERLING
  • V8
  • 100,000 MILES
My car engine light came on for a p0112 code. Went through fault isolation guide and change out air intake sensor then cleared code. Light came on again and gave same code. What could my problem be?
Wednesday, November 11th, 2020 AT 12:35 PM (Merged)
DAVE H
  • 13,383 POSTS
20) For KOEO & KOER Only DTC P0112 Or P0117: Simulate Opposite Signal To PCM
DTC P0112 (IAT) or P0117 (ECT) indicates sensor signal is less than self-test minimum. Minimum signal for IAT and ECT sensor is.2 volt or 250 °F (121 °C). Possible causes for these faults are:
Circuit Grounded In Wiring Harness
Faulty Sensor
Faulty Connection
Faulty PCM
Turn ignition switch to OFF position. Disconnect suspect temperature sensor connector. Inspect connector for loose, damaged or corroded terminals. Repair as necessary. Connect scan tool to Data Link Connector (DLC). Turn ignition switch to ON position. Using scan tool, access ECT-V or IAT-V PID from PID/DATA MONITOR & RECORD menu. For LS and Thunderbird with electronic throttle control, if PID value is 4.2 volts or less, or -40 °F (-40 °C) or more, go to step 22). All others, go to next step. If PID value is more than 4.2 volts, or less than -40 °F (-40 °C), replace faulty temperature sensor.
90) For Continuous Memory Only DTCs P0112, P0113, P0118, P1112 & P1117: Check For Intermittent
These DTCs indicate possible intermittent fault. Possible causes for these faults are:
Faulty Sensor
Faulty Sensor Connector
Open Or Grounded Circuit In Harness
Faulty PCM
Connect scan tool to Data Link Connector (DLC). Turn ignition switch to ON position. Using scan tool, access ECT-V and IAT-V PID from PID/DATA MONITOR & RECORD menu. While observing appropriate PID, tap on sensor and wiggle sensor connector to simulate road shock. If no change in PID voltage reading occurs, go to next step. If any change in PID voltage reading occurs, turn ignition switch to OFF position. Inspect connectors for loose, damaged or corroded terminals. Repair as necessary. If connectors are okay, replace faulty temperature sensor. If directed here for Continuous Memory DTCs P1112 and P1117, perform DRIVE CYCLES to verify repair. Repeat QUICK TEST.
CAMEY323
  • 89,000 MILES
When I start my truck, it cranks up but if I don't keep my foot on the gas it turns off. I took it to Meinke in February to get a tune up due to the check engine light being on. About a month later the light came back on I took it back and the guy told me it had to do with my gas pump being clogged. I notice that when I'm driving it seems like it wants to stop but when driving it runs smoothly.
SATURNTECH9
  • 30,870 POSTS
What's the exact code numbers you have? Also what size engine do you have?
CAMEY323
I have to look the paper up for the code my engine is 4.6
SATURNTECH9
  • 30,870 POSTS
Will the paper have the new codes after the repair and the light came back on?
KOKOTMG
Engine Performance problem
2003 Ford Expedition V8 Automatic 165000 miles
I have replaced coil pack & spark plug 7 because after a heavy rain, water pools in that area. After this rain and getting the same work done, the engine light stayed on, the mileage went from 18 to 13 and the engine seems to sputter, especially at lower speeds. I previously had 2 coil packs, #4 and #7 replaced and all spark plugs replaced. I've heard there may be a wire issue with the fuel injector. Can you help?
  • 108,005 POSTS
Honestly, the injectors on this vehicle are the most reliable part of the car, but that doesn't mean they can't go bad. Has the check engine light come back on for you for the same cylender?
KOKOTMG
  • 108,005 POSTS
Chances are either you are losing the signal for the injector or the boot that covers the plug is allowing an arc. Have you checked it closely for any evidence of that happening?
TEXDRAM
  • V8
  • 113,000 MILES
My ford expedition svc light came on the second it began running rough & misfiring.I had it the problem diagnosed at local auto parts & just as I expected it was one of the cop's.I made the replacement & the truck runs like it should. But my svc engine light is still shining - was there another step I left out?
OBXAUTOMEDIC
  • 3,711 POSTS
No, you will need to go back to the parts store and have them clear the code. Or you can wait 500 - 1000 miles or 50 - 100 key starts to reset light.
TEXDRAM
Makes sense - many thanks!
.[/Quote:7687fc6ea1]
