2003 Ford Expedition 2003 Expedition check engine light
PRIMETOM
  • 2003 FORD EXPEDITION
  • V8
  • AWD
  • 86,000 MILES
Had it scanned at autozone has code for faulty crankshaft sensor, misfire at cylinder 5 and lean fuel mixture. Where should I start?The guy at the store says to start at the sensor it may be causing the othe codes.
Do you
have the same problem?
Sunday, July 26th, 2009 AT 3:24 PM
BUDDYCRAIGG
  • EXPERT
I'd start with the crank sensor also.
Sunday, July 26th, 2009 AT 6:45 PM
Recommended Guides
