1999 Ford Expedition oil pan
UNLIMITEDTRADES
  • 1999 FORD EXPEDITION
Engine Mechanical problem
1999 Ford Expedition V8 Two Wheel Drive Automatic
can the oil pan be removed without removing anything else
Do you
have the same problem?
Saturday, May 29th, 2010 AT 3:18 PM
BLUELIGHTNIN6
  • EXPERT
No, you will have to remove different components to replace the oil pan gasket. It depends on what engine size you have as far as what all needs removed though.
Saturday, May 29th, 2010 AT 6:57 PM
DARRELL BISHOP
Have 2004 Ford Expedition XLT Triton V8 4.6. Same question as OP. Oil pan looks like it would clear the cross member. Just worried with screen an pick up tube might not let it clear? So I have to remove cross member?
Saturday, June 29th, 2019 AT 3:05 PM
DANNY L
  • EXPERT
Hello, I'm Danny.
DARRELL BISHOP
As far as clearance, Whether it being 2wd or 4wd to answer your question- yes the cross member has to be removed for oil pan removal/installation clearance. Hope this helps and thanks for using 2CarPros.
Danny-
Monday, July 1st, 2019 AT 5:17 PM
