1998 Ford Expedition replacing the front heater core
B_LOCO83
  • 1998 FORD EXPEDITION
Heater problem
1998 Ford Expedition V8 Two Wheel Drive Automatic
how to change the front heater core?
Do you
have the same problem?
Saturday, January 23rd, 2010 AT 4:55 PM
REMOVAL
1. Disconnect the battery ground cable.
2. Drain the radiator. Refer to: "Engine, Cooling and Exhaust : Cooling System : Service and Repair" See: Engine, Cooling and Exhaust Cooling System Service and Repair
3. Remove the instrument panel. Refer to: "Body and Frame : Interior Trim : Dash Board : Service and Repair" See: Body and Frame Interior Moulding / Trim Dashboard / Instrument Panel Service and Repair
http://www.2carpros.com/forum/automotive_pictures/12900_htc1_1.gif
4. Compress the holding tabs and disconnect the heater water hoses at the heater core.
http://www.2carpros.com/forum/automotive_pictures/12900_htc_1.gif
5. Remove the A/C plenum demister adapter.
1 Remove the screw.
2 Remove the A/C plenum demister adapter.
http://www.2carpros.com/forum/automotive_pictures/12900_hc2_2.gif
6. Disconnect the vacuum line.
http://www.2carpros.com/forum/automotive_pictures/12900_hc3_3.gif
7. Remove the heater core bracket.
1 Remove the two screws.
2 Remove the bracket.
http://www.2carpros.com/forum/automotive_pictures/12900_htc4_1.gif
8. Remove the plenum chamber top.
1 Remove the 13 screws.
2 Remove the plenum chamber top.
9. Remove the blend door assembly from the case.
http://www.2carpros.com/forum/automotive_pictures/12900_htc5_1.gif
10. Remove the heater core.
INSTALLATION
http://www.2carpros.com/forum/automotive_pictures/12900_htc6_1.gif
http://www.2carpros.com/forum/automotive_pictures/12900_htc7_1.gif
http://www.2carpros.com/forum/automotive_pictures/12900_htc8_1.gif
1. Follow the removal procedure in reverse order.
Saturday, January 23rd, 2010 AT 5:51 PM
Recommended Guides
