Need to know how to remove the top 2 bolts on expedition transmission without taking apart the top of the engine
Sunday, June 5th, 2011 AT 3:19 AM
MECHANIC
Never done this but with most transmissions to access the top bell housing bolts you will have to drop the cross member and lower the trans and use long extensions come over the top of the transmission, check this out this video which show the job being done.
Cheers
SPONSORED LINKS
Sunday, June 5th, 2011 AT 3:49 AM
SAPHIREFIRE277
MEMBER
It seems that on this particular model, the casing goes behind the motor so far that it's almost like to make an extra foot of space in the cab that they shoved all of these parts too far back to reach. Thank you, though, as they are across the street currently dis-assembleing the top of my engine :( (I know, my description is poor, I'm just the girl they sent searching for answers!)
Sunday, June 5th, 2011 AT 4:24 AM
MECHANIC
You can get to the bolts from under the car using a long extension just like in the video.
Sunday, June 5th, 2011 AT 7:29 AM
TOMCOOK
MEMBER
1 POST
2000 FORD EXPEDITION
138,000 MILES
Do u need to remove exhaust to remove the transmission from the truck
Friday, August 10th, 2018 AT 1:25 PM
(Merged)
MECHANIC
Yes, it gives much more acess room for the trans components.
SPONSORED LINKS
(Merged)
ANGELS1596
MEMBER
1 POST
1997 FORD EXPEDITION
Transmission problem
1997 Ford Expedition Four Wheel Drive Automatic
Can I replace a a 97 trans. 4.6 with a 99 trans. 5.7
(Merged)
MECHANIC
Hi:
We recommend staying with the exact replacement for the vehicle because they change things so often.
