Ford Escort
ROBH
  • FORD ESCORT
My 1996 Escort with 70,000 has been a solid dependable car. It was running fine when it died at an intersection. It will crank over fine but will not start at all. I've replaced the fuel filter, tested the fuel pressure (40 psi). I checked for spark with a timeing light and got a good flash. I inspected the timing belt and it was in good condition but just a little loose. I checked for error codes EOKO and got no codes at all. Any ideas of what might be the problem or what I might check next?
Do you
have the same problem?
Thursday, February 16th, 2006 AT 9:51 AM
LOVESCARS
Ignition control module//eec
Thursday, February 16th, 2006 AT 8:54 PM
Recommended Guides
