2003 ZX2 Ford Escort is flooded in only 1cyl.
TROUBLENEVERENDS
  • 2003 FORD ESCORT
I have a '03 ZX2 Ford Escort, 2.0, 5 speed, with 61,000miles. It's dumping gas in the engine and not starting. It gets spark, all fuses are good, fuel pump is working, but the injectors are flooding out. This is my only car and warrenty has ran out. What can I do or check?
I switch out the injectors and #1 cyl. Was still dumping to much fuel. Is this a computer problem or could it be something eles?
Do you
have the same problem?
Sunday, June 17th, 2007 AT 11:44 AM
GREENBLOOD
Check into cam position sensor malfunction.
Tuesday, June 19th, 2007 AT 10:58 AM
Recommended Guides
