1998 Ford Escort Timing Belt
JOYCEKELLY1974
  • 1998 FORD ESCORT
  • 4 CYL
  • 198,000 MILES
Timing jumped trying to replace timing belt but crankshaft wont rotate 360 degrees stops right before removed all the rocker arms and timing belt and still it does not rotate 360
Do you
have the same problem?
Tuesday, June 22nd, 2010 AT 2:52 PM
BMRFIXIT
  • EXPERT
Internal engine failure
Tuesday, June 22nd, 2010 AT 5:30 PM
Recommended Guides
