1997 Ford Escort TRANSSMISSION (STRANGE TROUBLE)
POMIE57
  • 1997 FORD ESCORT
I have a 1997 Ford Escort Wagon Automatic
94 k Miles. Trannsmission is strange. Sometimes it
works it dose not slip. Then all of a sudden nothing in any gear. If I reve the motor way up it ill engage a run perfect untill I let off then nothing. Then at time it will
run perfectly forward and backwards.
this makes no difference if the cars cold or warm.
ALSO in the shifter I here a buzzing sound when I shut
the motor off.
What can or should I do?
I had the tranni oil changed but no help.
thanks Jerry
cadydoo100@yahoo. Com
Do you
have the same problem?
Monday, April 9th, 2007 AT 10:30 AM
MERLIN2021
  • EXPERT
Sounds like your pump is dying.
Monday, April 9th, 2007 AT 11:06 AM
Recommended Guides
