1997 Ford Escort starter is turning but engine will not &qu
DANNY86
  • 1997 FORD ESCORT
  • 4 CYL
  • FWD
  • 175,000 MILES
Hi, here's the problem, when I try to start my car, when I turn the key and hold, the starter just turns and turns, and when I let go it just dies the engine will not "fire" and idle, it wants to but won't. I'm thinking it's a fuel issue, being the fuel pump, but I accessed the fuel pump from under the rear seat, and disconnected the lines, and turned the key fuel is pumping out. Could this be injectors? Or fuel filter? I really need help, and I need my car running until I can get a better car. Please help! Thank you in advance Daniel
Do you
have the same problem?
Sunday, November 9th, 2008 AT 10:52 PM
Have the ignition switch tested
Sunday, November 9th, 2008 AT 10:56 PM
Recommended Guides
