1997 Ford Escort Gear shift stuck in park position
CROFFEY
  • 1997 FORD ESCORT
  • 4 CYL
  • FWD
  • 102,000 MILES
My gear shift is stuck in park. I found a few blogs on replacing the brake switch which I have done and it did not help the problem. I have noticed that my brake lights do come on but my parking tail lights on the trunk do not but the outside ones do. I was going to check under the console but do not know how to remove it. I have also checked the fuses and they are fine.
Do you
have the same problem?
Tuesday, September 9th, 2008 AT 7:10 PM
BMRFIXIT
  • EXPERT
Check shifter interlock cable and solenoid
Tuesday, September 9th, 2008 AT 7:17 PM
Recommended Guides
