1996 Ford Escort I am having problems with radiator and a s
HIGHROLLER77
  • 1996 FORD ESCORT
  • 4 CYL
  • 130,000 MILES
I am having to put in antifreeze every 2days because of a bad leek in the radiator! How much would it cost to repair the radiator and is stop leek a good fix temporarily and what kind should I buy? I also have problems with the alignment the front wheel shakes really bad. What could be causing that?
Do you
have the same problem?
Thursday, October 21st, 2010 AT 10:34 AM
BILLYMAC
  • EXPERT
Lot's of stop leaks bars leak is prob the best However we can't reccomend stop leak as this stuff does not know the diff in your radiator or heater core or the coolant passages in the cyl head and block. Best to have radiator repaired a couple hundred bucks.
Shakeing in the front wheels means something is bad or bent most shops have free front end inspections I would go get one and they will also give you a estamate
Saturday, October 30th, 2010 AT 7:29 PM
Recommended Guides
