1996 Ford Escort
PGM43
  • 1996 FORD ESCORT
Engine Performance problem
1996 Ford Escort Front Wheel Drive Manual 98000 miles
i have 2 problems.1st when engine is warm and restarted automatic choke engages, but not as much as if cold.2nd after engine is warm and car is idling the engine rvs up and down for about ten seconds then settles but idling is not smooth.
Do you
have the same problem?
Friday, November 28th, 2008 AT 5:01 AM
Check the idle air control valve/motor
Friday, November 28th, 2008 AT 5:22 AM
Recommended Guides
