1995 Ford Escort rear lights out
BUDGETMAN102
  • 1995 FORD ESCORT
  • 4 CYL
  • 145,000 MILES
My rear lights both left and right are out. Only the brake lights and reverse lights are on. The fuse in the panel is good the bulbs are still good. How do I know if a wire or switch somewhere is the cause? My car is 1995 ford escort.
Do you
have the same problem?
Monday, October 20th, 2008 AT 2:37 PM
ZACKMAN
Do your front sidemarkers turn on? They are on the same circuit as the tail lights. Your 3157 tail light bulb has dual filaments, one for tail light and the other for stop light. Are they both good. A lot of time, you can't see that the filament burned out, but they are.
I would just try replace one of the bulb with a new one, and see what happens.
Tuesday, October 21st, 2008 AT 8:59 PM
Recommended Guides
