Radiator Leaking Coolant
AMANDA_SISK
  • 1999 FORD ESCORT
  • 5 CYL
  • 130,000 MILES
How do I change a radiator?
Monday, February 14th, 2011 AT 5:59 PM
SATURNTECH9
  • 30,870 POSTS
This guide will help walk you through the repair with a video to help you remove the hose clamp with instructions in the diagrams below to show you how on your car.
https://www.2carpros.com/articles/how-to-replace-a-car-radiator
and
https://youtu.be/S1q6HVe8Iw0
Monday, February 14th, 2011 AT 6:19 PM
AMANDA_SISK
Thank you
Monday, February 14th, 2011 AT 6:56 PM
SATURNTECH9
  • 30,870 POSTS
Your very welcome that's what were here for.
Monday, February 14th, 2011 AT 7:14 PM
IFAJDE
  • 1999 FORD ESCORT
  • 4 CYL
  • FWD
  • 92,000 MILES
My Ford Escort has a radiator leak. When I change my oil, auto service added approx. Quarter of coolant to it. However, I don't know since when leak exists. I know that leak will not get any better, only worst, but wonder how much time I have to fix my radiator before it does some damage to the motor.
Thanks,
I.F.
Thursday, April 16th, 2020 AT 2:22 PM (Merged)
OBXAUTOMEDIC
  • 3,711 POSTS
As long as you don't overheat the engine you will be fine just keep eye on coolant level.
Question for you.
Have you seen or noticed and coolant on the ground under you car?
When was the last time your coolant was checked?
Just because your coolant was a quart low doesn't necessarily mean you have a leak.
FONTANA
  • 11 POSTS
  • 1999 FORD ESCORT
  • 4 CYL
  • FWD
  • 128,000 MILES
Most say that the coolant can be drained through the radiator petcock, and to do a little better job a block drain plug can be opened if available. According to some manuals my car is suppose to have a block drain on the exhaust side but it sure isn't there- I checked and rechecked. Anyway, I tried draining thru the petcock but only about a quart came out. I replaced the quart with an extended life antifreeze which the manufacture said would replace all colors of antifreeze. Now I would like to flush the engine and replace the antifreeze. Since only a gallon came out of the petcock last time i'm figuring the radiator is a little blocked up near the petcock. Must I remove the radiator and clean it, or is there an easier way such as taking off the bottom hose and draining the engine, and then run water thru the radiator with the bottom hose disconnected - might that suffice to clean the radiator? Or could something else be the problem? Should I refill with extended life, and are there reasons why the extended life might not be as good as the original green?
Also the cooling system is supposed to have a float/seat de-gas system to aid in filling. What is this?
  • 108,164 POSTS
If it isn't draining, try removing the petcock the entire way. They has to be something blocking it. If you can't get it all out that way, remove the lower radiator hose and it will all drain. At that point, I would remove the upper hose, remove the thermostat, and flush the block out too. Also, get a quality radiator flush for the radiator and follow the manufacturer's recommendations. If that still doesn't help, then remove the radiator and have it rodded out.
FONTANA
  • 11 POSTS
Ok thanks.
Is the extended life coolant a good option?
What about the float/seat degas system? Does this mean that it will fill with thermostat closed, or just that I won't have to worry so much about air in system?
  • 108,164 POSTS
Yes, if the coolant is a universal type, it is good. As far as your other question, are you refering to the bleeder near the thermostat?
FONTANA
  • 11 POSTS
Thanks. Didn't get your last post until now-thought I would get email notification, so I hope you will still answer.
I don't know if there is a bleeder near thermostat, but the ford manual mentioned that "the thermostat housing has a float/seat degas system that improves coolant fill when radiator is closed". It didn't mention anymore about it or give anymore instructions. No mention of it in other manual.
  • 108,164 POSTS
That is a system that is designed to allow coolant enter the engine faster without removing the thermostat. It isn't anything you can adjust.
WESTFINN
  • 1998 FORD ESCORT
Engine Cooling problem
1998 Ford Escort 6 cyl Two Wheel Drive Automatic 90000k miles
How do you change the radiator in a 1998 Ford escort XL? Are there other parts you need to change at the same time?
Thank you so much
ORIGINALMINK85
It's actually pretty simple. First make sure your engine is completely cool, then go ahead and jack it up, get a bucket, and drain the radiator via the drain spout on the bottom corner of the radiator. Disconnect your hoses (including the metal ones), then remove the two little holders on the top of the radiator (should be a size 10 wrench or ratchet), and also a few nuts on the sides of the radiator that you will have to look for that will need to be taken off, then you can pull the radiator straight up out of the car. The fan is going to come with the radiator, so after getting it out of the car, just unplug the fan and unscrew it from the radiator and switch it over to your new radiator (unless your radiator came with a fan) If you're putting a used one in, make sure to flush it first, and also pay attention for leaks while flushing it. If you notice a leak, at least it saved you the problem of putting it in all the way and then discovering it, then just repeat the steps backwards. When disconnecting or reconnecting the hoses, you may need to finaggle the radiator a little to get the right angle on the hose clamps to get them off, but it's pretty easy. Also, make sure that when you put the clamps and hoses back on, that they are not twisted and that the clamps will be easy to access in case this ever needs done again. As far as changing anything at the same time, unless a hose, fan, or clamp is shot, the radiator is pretty much standalone on all escort models. After you're finished putting it back together and hooking up the fan wire and hoses, just fill it up and cap it and you're ready to go. I recommend going ahead and putting fresh antifreeze in it too.
FONTANA
  • 11 POSTS
Thanks for your help
WESTFINN
Originalmink85: I'd like to thank you for a very clear detailed answer - much appreciated.
  • 108,164 POSTS
HIGHROLLER77
  • 1996 FORD ESCORT
  • 4 CYL
  • 130,000 MILES
I am having to put in antifreeze every 2days because of a bad leek in the radiator! How much would it cost to repair the radiator and is stop leek a good fix temporarily and what kind should I buy? I also have problems with the alignment the front wheel shakes really bad. What could be causing that?
BILLYMAC
  • 2,204 POSTS
Lot's of stop leaks bars leak is prob the best However we can't reccomend stop leak as this stuff does not know the diff in your radiator or heater core or the coolant passages in the cyl head and block. Best to have radiator repaired a couple hundred bucks.
Shakeing in the front wheels means something is bad or bent most shops have free front end inspections I would go get one and they will also give you a estamate
HARLEYBOY95
  • 1996 FORD ESCORT
  • 4 CYL
  • 150,000 MILES
How would you know if the radiator needs replaced?
Start car and let it come up to operating temperature, now start feeling the front of the radiator for cold spots if any present its a sign of clogging and not necessarily needs replacing-but a good flushing job, don't work needs replacement
