Upper cylinder head torque specs
WILLIAM HANSEN
  • 2000 FORD ESCORT
  • 2.0L
  • 4 CYL
  • FWD
  • MANUAL
  • 196,000 MILES
I am a mobile tech and computer crashed with my Aldata on it?
Saturday, September 6th, 2014 AT 3:41 PM
WRENCHTECH
  • 20,757 POSTS
I assume this is a VIN 3 engine. I also assume you are referring to the cam bearing caps. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
https://www.2carpros.com/images/external/84779939.gif
Sunday, September 7th, 2014 AT 5:48 AM
BIGGY25
  • 1994 FORD ESCORT
1994 Ford Escort 4 cyl
what is the tightening sequence and torque for the head on a 1994 escort engine?
Thursday, January 28th, 2021 AT 9:51 AM (Merged)
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,787 POSTS
Hey BIGGY25,
Here is the cylinder head bolt tightening sequence and the foot pound and newton meter specs.
Cylinder Head Bolt (1) 56-60 (76-81)
Please let us know if you need anything else.
Best, Ken
STEVEN82
  • 1993 FORD ESCORT
  • 4 CYL
  • FWD
  • MANUAL
  • 137,000 MILES
What are the spec for the torque on cylinder head
Thursday, January 28th, 2021 AT 9:52 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
1.9L engines..
Tighten the cylinder head bolts in sequence (refer to the illustration) to 44 ft. lbs. (60 Nm).
https://www.2carpros.com/forum/automotive_pictures/261618_0900c1528008da7a_1.jpg
1.8L engines..
Tighten the bolts in the proper sequence (refer to the accompanying illustration) in two or three steps to 56-60 ft. lbs. (76-81 Nm).
https://www.2carpros.com/forum/automotive_pictures/261618_0900c1528008da6a_1.jpg
Thanks for using 2CarPros.com!
STEVEN82
  • 1993 FORD ESCORT
Engine Mechanical problem
1993 Ford Escort 4 cyl Front Wheel Drive Manual
what are the head torque specs
BMRFIXIT
  • 19,053 POSTS
1.8 L 56-60ft-lb
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_191.jpg
1.9L
step 1 30-40ft-lb
step 2 loosen all bolts 2 turns
step 3 44ft-lb
step 4 additional 90 degrees
step 5 additional 9 degrees
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic2_93.jpg
