1994 Ford Escort engine seems to stall
BERT83
  • 1994 FORD ESCORT
  • 4 CYL
  • FWD
  • 15,700 MILES
I have a 94 escort 1.9L I have changed plugs, wires, air filter, fuel filter, also fuel system treatment. The cars reads 157,000 miles but engine was replaced with a reman about 8,000 miles ago. The will run smooth whenit is cooler outside but when its in the 90's the car developes a slight stall at around 40-50 mhp and around 1,500-2,000 rpm. Any suggestions?
Do you
have the same problem?
Friday, August 8th, 2008 AT 11:57 PM
BMRFIXIT
  • EXPERT
Check fuel pressure
and fuel pump
Saturday, August 9th, 2008 AT 12:03 AM
Recommended Guides
