1993 Ford Escort no power to blower
DANIEL6
  • 1993 FORD ESCORT
  • 4 CYL
  • FWD
  • MANUAL
  • 150,000 MILES
There is no power reaching the blower. The blower motor is fine. I don't know how to check the circuit breaker on the fuse box.
Do you
have the same problem?
Wednesday, May 20th, 2009 AT 2:42 PM
MMPRINCE4000
  • EXPERT
Just pull the fuses one at a time and check each one. You can buy a simple fuse tester at most autoparts stores for around $10.
Check each fuse and utilize the process of elimination.
If fuses are OK, it may be the blower switch.
Wednesday, May 20th, 2009 AT 2:49 PM
Also test the blower motor resistor see wiring diagram
http://www.2carpros.com/forum/automotive_pictures/12900_blower_motor_15.jpg
Wednesday, May 20th, 2009 AT 3:00 PM
Recommended Guides
