1993 Ford Escort My Ford Escort LX won't start, won't turn
SMIRLZ06
  • 1993 FORD ESCORT
Electrical problem
1993 Ford Escort Front Wheel Drive Manual 95000 miles
I have a 1993 Ford Escort LX 2 door, 1.9L, and it won't start, it wo't even try to turn over. It seems to me that it is electrical, since the dashlights won't come on either.
I've been dealing with this problem for over a month now. Car has been to the shop 6 times, all they did was rebuild my starter. (Which had gone bad, but works fine now.) But The car will completely shut off at random times 2 or 3 times a day(especially on hot days), even when I'm in traffic. If I'm lucky enough to get it to the side of the road while it still has momentum, I pop the hood, but nothing looks out of place, nothing is burning or leaking, and nothing is loose. When the car shuts off like this, it's completely dead. No dome lights, no dash lights, nothing. It's like someone took the battery out. (And the battery is fine, had that checked). But if I let the car sit for 5 minutes, I can get it started again. But if I try before the 5 minute period, nothing but the headlights turn on. And there's a very fast clicking from the dash when I turn the headlight nob, then everything shuts off again. Then I must wait another 5 minutes WITHOUT TOUCHING ANYTHING to get it to start. My mechanic thought that this problem was caused by some arcing in the fuse box in the engine. He also mentioned the bottom of the fuse box is melted from the arcing of this fuse that is bolted into the box. So he tightened that bolt on the side of that fuses and said "that should do it". It worked for 4 days, where the car didn't shut off at all. Then yesterday, the problem came back. And the car wouldn't start, even after waiting the 5 minutes. All it does is click when I try to start it or turn anything on. Me, my husband, and my trusted mechanics are all stumped on this problem. Can anyone give me any ideas on how to fix this? Please? Thanks.
Do you
have the same problem?
Friday, September 11th, 2009 AT 12:28 PM
LAZYGAZER
I have a question before rendering a diagnosis. Has the heater core ever been replaced due to leaking coolant. Let us know.
Wednesday, September 16th, 2009 AT 4:53 AM
Recommended Guides
