1992 Ford Escort
JISBALLARIFIC66
  • 1992 FORD ESCORT
  • 4 CYL
  • FWD
  • 69,000 MILES
My car started slipping gears, I parked on the side of the road to check the fluid it was nearly full so I got back in my car to leave I put it in reverse and it doesnt move so I put it in park and then into reverse and it moves a little bit then stops I tried giving it gas but it didnt move then I put it in park hit the gas a little bit and put it in reverse at the same time and it jerked backwards and made a loud bang. I then put it in drive and drove forward and it reved really high and then switched gears and it would do the same thing rev really high and then the next gear would catch. My guess is either simply and timing problem or a new transmisssion.
Do you
have the same problem?
Monday, June 7th, 2010 AT 12:32 AM
Get a used tranny from the nearest junkyard
Monday, June 7th, 2010 AT 1:22 AM
Recommended Guides
