When I turn the key to the ON position, I don't hear the fuel pump power up. I have checked all fuses and relays and also the inertia switch. Everything is good there. I had to replace the fuel rail, injectors and the fuel rail wiring harness. Checked the connected on the fender wall where the harness plugs in and it appears not to be damaged.
What other components can I check for damage? Wiring harness along the firewall? What can I do to troubleshoot this. I am familiar with testing with a DVM.
SPONSORED LINKS
have the same problem?
Saturday, May 26th, 2012 AT 6:43 PM
