Alternator replacement?
JACKTMCCALL
  • 2017 FORD ESCAPE
  • 2.5L
  • 4 CYL
  • 95,000 MILES
I replaced my alternator and now all my lights and electrical is going nuts. Battery was dead, jumped battery to get it started and as long as I leave the charger boosting the battery my car runs fine, but when I disconnect the charger everything goes crazy. Do I maybe need a new battery, did I do the job right can you help me make sure?
Do you
have the same problem?
Monday, January 27th, 2020 AT 6:00 PM
  • 52,797 POSTS
Good evening,
You have a low voltage from the battery. I would start by charging the battery and see if it starts okay.
https://www.2carpros.com/articles/how-to-charge-your-car-battery
Chances are you will be replacing the battery.
Here is how to change out the alternator correctly in the diagrams below. Check out the diagrams (Below). Please let us know what you find.
Monday, January 27th, 2020 AT 6:12 PM
JOHNIE TAYLOR
  • 6 POSTS
  • 2010 FORD ESCAPE
  • 6 CYL
  • 4WD
  • 100,000 MILES
How big of a job is it to replace the alternator?
Tuesday, August 11th, 2020 AT 5:33 PM (Merged)
DANNY L
  • 5,648 POSTS
Hi there, I am Danny.
On a scale of 1-10 I would give it a 5. You will need a serpentine belt tool to remove and install belt and a basic set of metric tools. Disconnect battery cable first, then remove belt. The alternator is held on by a few bolts and electrical connections. Attached is a tutorial explaining the process. Hope this helps and feel free to ask any questions if you feel like tackling this!
Danny-
https://www.2carpros.com/articles/how-to-replace-an-alternator
COURTNEYKCAVILL
  • 2007 FORD ESCAPE
  • 3.0L
  • 6 CYL
  • 1,000,000 MILES
Need to know exactly what tools and sizes I need to replace my alternator?
I attached the process to replace the alternator. Unfortunately, they don't list tools needed so this is going to be something that you have to try to find out what you need. However, from what I remember, you can do this job with a basic set of wrenches and sockets.
Sorry I can't give more detail about the tools.
EDPRATHER
  • 2004 FORD ESCAPE
  • 6 CYL
  • AWD
  • 76,400 MILES
How do I get to and remove the alternator on my V6 2004 Ford Escape?
BLUELIGHTNIN6
  • 16,542 POSTS
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_818.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Noname2_209.jpg
RUSSELLZ260
  • 2003 FORD ESCAPE
  • 167,000 MILES
Steps to removing and replacing the alternator, how and what do I have to do to remove it from the car i'm stumped
Tuesday, August 11th, 2020 AT 5:34 PM (Merged)
JDL
  • 16,098 POSTS
Not sure of litre size of engine? You may have to access generator from passenger side wheel well. Safely raise and support the vehicle, remove tire, remove splash lining.
You need to take battery connections loose.
GEAR1986
  • 2003 FORD ESCAPE
  • 6 CYL
  • FWD
  • 72,000 MILES
How do you remove the alternator from a 2003 ford escape.
DUSTIN1980
You have to take the cv axle out and remove it through that opening
CAVE MANN
  • 7 POSTS
  • 2003 FORD ESCAPE
  • 3.6L
  • 6 CYL
  • 4WD
  • 166,000 MILES
After changing the alternator and the pig tails clipped because I broke it it I rewired a new pig tail clip and the altenator charged the battery. After 2 weeks the alternator stop charging but still no charg where is the short than where is the short thank you
HMAC300
  • 48,604 POSTS
Recheck your wiring job first if it wasn't soldered together with shrink tube then re do it like that. Then check the fuses in pic you probably blew a fuse for it.
CAVE MANN
  • 7 POSTS
Then why do battery light come on when I touch the green and red wire to the body of the alternator
HMAC300
  • 48,604 POSTS
Because the battery light is the charge indicator light and it means you aren't charging your battery
ERICGREGORY
  • 2002 FORD ESCAPE
2002 Ford Escape
removal of the alternator where is the halfshaft
BLUELIGHTNIN6
  • 16,542 POSTS
4 cylinder or 6 cylinder?
MJR346
  • 132 POSTS
My guess is v6 and the right cv axle shaft is called a half shaft. It requires complete removal to replace the alternator. And needs a new axle nut torqued to roughly 200 lb/ft if I remember. Something that most 1/2 drive torque wrenches (common biggest size for sale in most tool places such as Sears) don't go up to.
AHEW1960
  • 2002 FORD ESCAPE
  • 6 CYL
  • FWD
  • 120,000 MILES
What is the best way to remove the alternator?
BLUELIGHTNIN6
  • 16,542 POSTS
Have to remove axle first. Use 18" extension with 13 mm socket. Use same setup for removing top alternator bolt. Extension fits between exhaust hanger and frame. Remove plastic shield behind axle (2 clips and hooked onto steering rack) and alternator bracket to engine (3 bolts). The alternator must be twisted a few ways to fit between the crank pulley, block and frame but it will fit without having to remove exhaust. Will take around 2 hours for the job
