The Front Airbag Light just came on
ESCAPE4WDFORD
  • 2003 FORD ESCAPE
  • 149,753 MILES
The Front Airbag Light just came on.
It flashes the code: 4 - 6. What does that mean?
Wednesday, February 27th, 2013 AT 3:55 AM
  • 52,797 POSTS
We need the primary code first, then we can find the secondary code that you gave us.
Wednesday, February 27th, 2013 AT 4:21 AM
ESCAPE4WDFORD
Using my Actron Auto Scanner Plus, Model CP9580A there is No Code that comes up. The only information is that the Front Airbag Light on the instrument panel flashes 4 times, pauses, then flashes 6 times then stays continuously lit. Waiting for reply.
Thursday, February 28th, 2013 AT 2:59 AM
  • 52,797 POSTS
The fact that it stay lit means there is indeed a fault/code. Perhaps a different scan tool will be able to read it. I did find a Tech Service Bulletin on your SRS system though, if this hasn't been addressed it may need to be
Here's a video that might help
https://youtu.be/gnSGfEqrf_w
See attachment below
Saturday, January 12th, 2019 AT 5:21 PM
ESCAPE4WDFORD
  • 2003 FORD ESCAPE
  • 149,753 MILES
Why is my Front Airbag Light flash?
The flashing code is 4 pause 6.
Saturday, January 12th, 2019 AT 5:23 PM (Merged)
  • 52,797 POSTS
Once again, we need the code from the scan tool to start the process
ESCAPE4WDFORD
I have no code. Sorry?
  • 52,797 POSTS
Go to a parts store and have them pull the code for you.
BOSTONGIRL39
  • 2010 FORD ESCAPE
  • 6 CYL
  • 41,263 MILES
My airbag light is on and I am looking to see how much it will cost to replace part. I was told I would have to replace OCS module and bladder.
Did Ford company ever have a recall on the airbag light?
Thank you very much.
Regards,
Mildred Butler
CARADIODOC
  • 33,727 POSTS
I do not know what either of those parts are, and it is not likely two parts failed at the same time. Do you have the exact diagnostic fault code number? If you supply that, I can look up its meaning.
BOSTONGIRL39
This is what was given to me - 85 Accessories - 1092 CPT - They verified concern test RCM. B2909 OCS hard fault code pin point test. Test wiring from OCS to RCM OKI performed system reset could not reset. Need too replace OCS Module and Bladder. This is the information that was given to me at a cost of $2574.18 including labor which I already paid labor just to have them look at it. I hope this help yopu, as this is all I have.
Thank you
CARADIODOC
  • 33,727 POSTS
B2909 refers to the Passenger belt tension sensor, specifically a wire to it could be open or grounded. In 99 percent of cases, the circuit has a problem that must be diagnosed. The computer has to be working to detect the problem, so there is no need to replace it. In a very rare one percent of the time, a defect inside the computer can cause it to falsely set a fault code. The computer is only suspect when testing shows there is no defect in the circuit.
I still don't know what is meant by "bladder". If that refers to one of the air bags, those are only replaced if one has been set off in a crash.
TRAINERD2000
  • 2002 FORD ESCAPE
  • 6 CYL
  • 107,000 MILES
My airbag light stays on and I would like to know if I can disconnect that light without disconnecting other warning lights. Also is there a way to check the airbag mechanism and repair it? I cannot get an inspection sticker without this being rectified.
SCOTTY DEE
  • 592 POSTS
No way to disconnect the light. The SRS control module should be scanned for trouble codes. There will be a code stored and with that we will know which diagnostic flowchart to follow.
RJ220171
  • 2002 FORD ESCAPE
  • 6 CYL
  • 140,000 MILES
My airbag light has recently turned on. What does it mean, and what can happen to the car?
BLUELIGHTNIN6
  • 16,542 POSTS
Indicates a fault in the SRS (supplemental restraint system). Most likely simply due to a faulty sensor. Nothing will happen to the vehicle. You need to have a diagnostic scan on done to the vehicle so they can retrieve the trouble codes stored by the SRS
MMOTOOLE
  • 2004 FORD ESCAPE
  • 6 CYL
  • 55,000 MILES
The air bag light is flashing a code 46. Do you know what this translates to? Thank you very much. Maggie
  • 31,938 POSTS
Hi there,
Thank you for the donation,
This is a fault with the electrical connection to the drivers seat belt pretensioner, any SRS work should be referred to a qualified mechanic or a dealer.
Mark (mhpautos)
RROCK1952
  • 2004 FORD ESCAPE
  • 6 CYL
What does a blinking air bag light indicate?
  • 31,938 POSTS
There Is an error in the SRS system, a scan will give you the fault code, any SRS work must be done by a qualified tech as this system is extremely dangerous to work on, while the light is on, the SRS system is inactive.
Mark (mhpautos)
ROMEO BELL
  • 2002 FORD ESCAPE
  • 262,467 MILES
On my ford escape the air bag light stays on when every I am driving.
