Inertia switch location
KPHIL4
  • 1991 FORD E-SERIES VAN
  • V8
  • 13,800 MILES
Where is the fuel pump safety reset switch location on 1991 ford econoline van, if there is one?
http://www.2carpros.com/forum/automotive_pictures/151172_HandiCapsale001_2.jpg
Do you
have the same problem?
Thursday, January 31st, 2008 AT 1:23 AM
The switch is called the fuel cut off inertia switch located under the right side of dash, on the heater plenum.
Here is a guid to help you test the relay
And the fuel pump relay is on the right front fender panel near the battery. See below
Thursday, January 31st, 2008 AT 2:15 AM
RAMMAXSON
  • 1994 FORD E-SERIES VAN
Where can I find the fuel pump reset button? On a 94 Econoline conversion van 57L V8 w/100K ml? And how much fuel should the fuel pump pump out with the filter disconnected. Per revolution of the engine?
Friday, November 2nd, 2018 AT 11:50 AM (Merged)
PEPPERMRJ
  • 1,158 POSTS
Don't know where the inertia switch would be. All the book says is that it is located in the cab. Try giving your dealer a call. There is no volume spec for fuel pump output. Measure pressure at the rail. Should be 35 to 45 lbs.
Good hunting and let us know where you find it. :)
JPTWOTIMES
  • 5 POSTS
  • 1987 FORD E-SERIES VAN
  • 6 CYL
  • 80,000 MILES
Where can I find one?
DOCFIXIT
  • 18,828 POSTS
Behind right kick panel underdash
