2002 Ford Crown Victoria Fan Works Sometimes
HAMIL2000LB
  • 2002 FORD CROWN VICTORIA
  • V8
  • 160,000 MILES
My AC system is cooling however, the fan does not always come on. Sometimes the fan works, sometimes it does not. I can tell the system is cooling because I feel cool air seeping out of the vents. But the fan is sporadic. Even with the AC off, the fan works sporadically.
Any thoughts on what this might be? Could it be an easy fix?
Do you
have the same problem?
Tuesday, July 21st, 2009 AT 11:11 AM
WAY2OLD
Are you talking about the a/c blower fan? Or are you talking about the engine cooling fan? If it is the a/c fan, it will either be the blower switch, blower resistor or the blower motor itself. Any of the things are fairly easily replaced.
Tuesday, July 21st, 2009 AT 6:40 PM
HAMIL2000LB
Thanks for the reply. Yes, its the AC blower fan. I'll check what you mentioned and see if that fixes it.
Thanks!
Wednesday, July 22nd, 2009 AT 7:33 AM
Recommended Guides
