Transmission Trouble
MRTACHINE
  • FORD CONTOUR
I have a 1995 Ford Contour, 180,000 miles, 2.0 automatic. The car runs good for about 20 to 30 miles but, then it won't shift until after it cools for awhile. It only goes 100 yards and then it repeats. I drained the transimission fluid about 4 times but still does the same thing. The fluid will be alot darker than normal and there's also a burnt smell to it. Could the problem be the PCM (powertrain control module) or the transmission fluid filter? :(
Do you
have the same problem?
Tuesday, March 13th, 2007 AT 12:41 PM
SHELBYGT
It could be your transmission
Wednesday, July 18th, 2007 AT 1:25 PM
Recommended Guides
