Ford 1997 Contour
BORIST
  • 1997 FORD CONTOUR
I have 1997 Ford Contour GL (4 cylinders)with 63000 miles. Lately the car stalls when pulling out of a parking spot or parallel parking. The problem is mostly associated with low speed revers movement with wheel being turned. I do not recall it stalling with a straight wheel position. Thank you, BorisT
Do you
have the same problem?
Monday, May 21st, 2007 AT 9:37 AM
SHELBYGT
Fuel filter clogged
spark plugs
vacuum leakage
Wednesday, July 18th, 2007 AT 1:03 AM
Recommended Guides
