98 Ford Contour replaced crankshaft sensor and modulare che
DAWN39JONESBORO
  • 1998 FORD CONTOUR
And ignition moduler checked out do you have any idea what else it could be its still cranking just not starting, starter seems find, everything else checks out please someone help also the crankshaft sensor I got that matches my car is longer then the other one and the whole where the bold goes is on the top not the bottem could this cause a problem
Do you
have the same problem?
Friday, November 17th, 2006 AT 1:06 PM
KEN
  • ADMIN
Have you checked the fuel pressure?
Friday, November 17th, 2006 AT 2:12 PM
Recommended Guides
