2000 Ford Contour
CNCRSRVIVR1229
  • 2000 FORD CONTOUR
I have a 2000 Ford Contour se, 74000 miles, 5 spd v6 and when I'm driving the car is pretty quiet. When I turn it off after driving for a while, it sounds like there is a whirring noise from under the hood. Almost as if it is winding down.
I just had a lot of work done on the wheel bearings and alignment. Do you have any suggestions as to what would cause the engine to make that noise?
Do you
have the same problem?
Sunday, June 10th, 2007 AT 6:31 AM
MERLIN2021
  • EXPERT
The cooling fan. Noise is normal.
Sunday, June 10th, 2007 AT 8:06 AM
Recommended Guides
