1999 Ford Contour starting car
DADDYROSE
  • 1999 FORD CONTOUR
  • 6 CYL
  • FWD
  • 183,680 MILES
My car makes a moaning sound when I turn the key in the ignition. After I turn the car off and try it again it starts without any problem. I've been doing this for a while till one day the car wouldn't start. I took it to a shop and they found nothing wrong with it. I took it home and it started working on the first try. Now after a few weeks it's started doing the moaning sound and then starting off fine on the second try. What instructions could you give me to correct the problem? Your advice would be greatly appreciated. Thanks, Raul.
Do you
have the same problem?
Thursday, September 11th, 2008 AT 11:09 PM
BMRFIXIT
  • EXPERT
Check /replace starter
Friday, September 12th, 2008 AT 6:22 AM
Recommended Guides
