Fuel Pump
ANNLHARDING
  • 1999 FORD CONTOUR
  • 4 CYL
  • FWD
  • 113,000 MILES
How must would it cost to replace a fuel pump in a 99 Ford Contour? I live in Derry NH
Thursday, December 23rd, 2010 AT 2:51 PM
JDL
  • 16,098 POSTS
I don't know about your part of the country? I charge 100 bucks for diagnostics. 50 bucks an hour for labor, two hour minimum. If I run into something I don't expect, it will cost more. Different shops charge different labor rates and parts are extra.
Thursday, December 23rd, 2010 AT 2:57 PM
WRENCHTECH
  • 20,757 POSTS
The fuel pump itself for this vehicle lists for about $450 from the dealer. There are some aftermarket pumps made that may save you a little money but remember, you get what you pay for, I have seen many issues arise after using aftermarket pumps vs OEM. The flat rate labor time is 2.2 hours so you can calculate that from the shop's labor rate. For example. At a labor rate of $80 per hour, that would be $176 in labor. You should also replace the fuel filter at the same time.
Thursday, December 23rd, 2010 AT 3:27 PM
ANNLHARDING
So I'm looking at about $600-$700 to replace. Thank you all very much.
Thursday, December 23rd, 2010 AT 4:10 PM
STUDNT4ART
  • 1999 FORD CONTOUR
  • 4 CYL
  • FWD
  • 150,000 MILES
Car came without a manual and we have been trying to locate the fuel pump. Does someone know where it is?
Thursday, April 11th, 2019 AT 5:06 PM (Merged)
ENGINEMAN 73
  • 28 POSTS
Pull up the rear seat and remove large rubber grommet. You can access pump but it will not fit through the hole. I took a pair of visegrips and bent outside edge back to remove strainer and pump. You can bend them back down when you are done. Not real professional but it will work.
STUDNT4ART
Thank you very much for your reply. Now we need to figure out how to get the rear seat out. Lol
ENGINEMAN 73
  • 28 POSTS
The best I can remember is pulling up pretty. Try 1 person on each side and jerk upward.
STUDNT4ART
Thanks! Got it
RGANZZLLAS
  • 2000 FORD CONTOUR
Electrical problem
2000 Ford Contour 4 cyl Automatic
i replace my fuel pump few days ago because the gauge didn't read how much gas was in the tank. Gauge still doesn't work properly, but I think I did something wrong. A day after replacing the pump, my battery died completely. Bought brand new battery, same problem: keeps dying when plugged in. When I unplug the battery, it still has juice. I assume that something is draining the battery and I wonder if the fuel pump is staying on or is it the relay. The alternator is fine as well. I haven't checked the regulator on the alternator. Before replacing the pump, the car was fine. Now, not so much. That's is the only thing that was touched and messed with. Please tell me what is draining my battery.
STUDNT4ART
Wow we got the fuel pump out but the fuel lines connects disintegrated. Normal? Will the ford parts dealer be able to order for us new fuel lines and do you need anything special to attach those? Please any info we need that you know would be a huge help. We will be going in tomorrow morning for the pump. Thanks again, you guys are awesome!
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
When you turn the car off can you still hear the fuel pump humming in the tank? Also, when disconnecting and connecting back the battery, listen for a relay to click. If it does click then it must be stuck and needs replaced.
ENGINEMAN 73
  • 28 POSTS
Hi, what tore up fuel lines on pump or lines that disconnect from pump? If they are lines on pump they come with new pump module. If the lines going to pump tore up you will have to replace them from dealer. Most fuel lines either have a clip that holds them in place or a tool from autozone that slips in behind line to disengage. Use caution when working around fuel tank the vapors are rising and spreading out and a spark would cause an explosion. Disconnect battery and disconnect power plug at pump. Clean surface well and use a light coating of heavy grease on rubber o-ring to seal new pump module with tank ring. After you install new pump turn key on but do not try to start for 10 seconds to pump up pressure. Any other questions reply and I will try to help.
RGANZZLLAS
I never head the pump before and I don't hear a clicking noise when plugging the battery back in.
BLUELIGHTNIN6
  • 16,542 POSTS
Okay, your fuel pump could be wired up wrong then, are you certain all connections were put back where they should be when replacing the pump? Also test the fuel pump relay
PERRY13
  • 1999 FORD CONTOUR
  • 6 CYL
  • FWD
  • 140,000 MILES
I recently bought this car from a private owner. I bought the car knowing that the alternator was bad. I bought the alternator but haven't had a chance to put it on yet due to the labor required. I drove the car around a little and it died on me. I charged the battery thinking that was the problem and it still would not start. It tries to turn over, but will not start. The first time I had this problem, I changed the fuse to the fuel pump and it started up just fine. Two days later the car died and had the same problem. No fuel pressure in the line. This time the fuse is not blown so I have no idea what to do. I changed the fuse again anyway and it still will not start. I also checked the power to the fuel pump and it is getting power. I think it is the fuel pump but my father insists that the problem is something else. Can anyone give me advice on what to do?
JDL
  • 16,098 POSTS
Did you check the actual voltage reading on both side of pump connector. If you have good voltage and ground at the pump and no pump action, I suspect the pump. Did you try banging on the bottom of the tank, to see if pump will take off running?
PERRY13
I only checked it with a test stick with the lightbulb to see if it was getting power period. And the alternator itself isn't bad I don't think, it's just the volage regulator which is inside the alternator
AJVANDYKE
  • 36 POSTS
If you already have the alternator w/voltage regulator I would go out of your way and change that first since you already have the part. Or atleast check to see if it is bad for sure because even if you get the problems in the fuel system worked out your car will still not work right if the alternator/voltage regulator is bad. I would also have the battery checked out just to make sure.
How did you check for fuel pressure? Do you have any kind of readings for the fuel pressure? Can you get a voltage measurement at the pump? Does you car turn over? If it does, does it seem to turn over slower then normal? Anymore infomation would be a great help
ABEAMON0318
  • 1999 FORD CONTOUR
  • 4 CYL
  • 4WD
  • MANUAL
  • 163,000 MILES
I have a 99 Ford Contour that apparently has to have the fuel pump repaired. Is it worth it to go ahead and have it fixed or should I just scrap the car? A bit of background I also just got a new clutch, and when I bought it 6 months ago the previous owners had put in a new starter, battery, tires, and brakes.
WRENCHTECH
  • 20,757 POSTS
Why would you scrap a '99 car over a fuel pump? Is the rest of the car that bad?
