1995 Ford Contour no spark at #2 cycl
TIMEBAY
  • 1995 FORD CONTOUR
Engine Mechanical problem
1995 Ford Contour 4 cyl Front Wheel Drive Manual
cut off car went back stared it up was missing, check not firing at #2 cycl replace plug&wire no fire, can take out plug ground it to metal have firing but no spark when plug is back in engine
Do you
have the same problem?
Tuesday, March 24th, 2009 AT 9:14 AM
DOCFIXIT
  • EXPERT
Maybe be injector not supplying fuel
Wednesday, March 25th, 2009 AT 11:54 AM
Recommended Guides
