1992 Ford Contour Timing belt
ILL_APPL2005
  • 1992 FORD CONTOUR
Engine Mechanical problem
1992 Ford Contour 4 cyl Front Wheel Drive Automatic
A friend said if the timing belt on my 92 escort ever broke, the engine was trash. My belt just broke. Is this true, or can it be repaired?
Do you
have the same problem?
Wednesday, April 22nd, 2009 AT 6:52 PM
BMRFIXIT
  • EXPERT
Ford escort chance should be OK
replace the belt and do a compression test
I believe it should be OK
do the belt and start it only way to find out for sure
Wednesday, April 22nd, 2009 AT 7:20 PM
