89 Bronco no start when motor is hot
VAREBELLADY
  • 1989 FORD BRONCO
I have a 89 full size bronco 4X4 with about 96,000 miles. I am having the problem of it is a slow start when cold. So I replaced the old battery. It is still a slow start however now when the motor is hot or after I get it started and go some where the truck will not start. I sounds like it is trying kinda like the battery is bad but it will not start. However if I wait about a half-hour to a hour it will start with the same slow cranking start. Anyone out there have a clue what is wrong with my baby? HELP
Thanks
Cindy
Do you
have the same problem?
Tuesday, April 4th, 2006 AT 11:46 AM
LOSONE
Sounds like you need a new starter. Good Luck
Tuesday, April 4th, 2006 AT 4:41 PM
Recommended Guides
