1995 Ford Bronco WILL NOT START
WILL WHALEY
  • 1995 FORD BRONCO
  • V8
  • 4WD
  • 138,000 MILES
My 1995 Bronco 5.8l ran beautiful but now it will not start.I hooked the code reader up and itells me system passed. The engine turns over but it will not even try to start.
Thanks
Will Whaley
Do you
have the same problem?
Saturday, August 22nd, 2009 AT 10:18 AM
KHLOW2008
  • EXPERT
Hi Will Whaley,
Thank you for the donation.
When engine refuses to start, there are basic items that you need to check, such as missing sparks or fuel. Click the following link and check out the symptoms listed. Go through the ones that matches your symptoms and find out what is missing. Let me know what you find and I will assist you from there.
http://www.2carpros.com/kpages/first_things.htm
Saturday, August 22nd, 2009 AT 11:15 AM
Recommended Guides
