1995 Ford Bronco fuel injection issue
ANNIE121150
  • 1995 FORD BRONCO
Engine Performance problem
1995 Ford Bronco V8 Four Wheel Drive Automatic exempt miles
I ran out of gas, and when I put gas back in it wouldnt start. It acts like it is trying to start, and will but very briefly then dies. It is fuel injected, so I dont know if I have to do something special for it to start. Been trying all day.I was told by my son that it may be an air bubble. And if so how do I get it out. Some gas is getting to the engine but not enough for it to stay started. Help please.
Do you
have the same problem?
Friday, August 29th, 2008 AT 7:40 PM
BADBO
Can you hear the fuel pump running when you just turn the key on. It should run about two seconds only? Check fuel pressure with guage. There is a place under the hood in the test plug (Data Link Connector) to crossover and the fuel pump will run all the time to check it. I tried to find a picture of the plug but could not. Hope this helps.
Badbo
Friday, August 29th, 2008 AT 8:03 PM
Recommended Guides
