1995 Ford Bronco exhuast
SPIKE161616
  • 1995 FORD BRONCO
  • V8
  • 4WD
  • 170,000 MILES
When my truck is cold, an I start it up, a ton of white smoke comes out of the exhaust. It does that for about 2 mins, then goes away. The all the gauges are all normal the entire time
Do you
have the same problem?
Wednesday, October 13th, 2010 AT 7:28 PM
BMRFIXIT
  • EXPERT
Suspect valve seals
Check if loosing oil
Wednesday, October 13th, 2010 AT 7:33 PM
Recommended Guides
